Ray2
Apr 16, 2016Luminary
Help for home folders and sharing connections
RN314- OS 6.2.4 Windows 7 Pro So far, I have not created any additonal user accounts and only have "admin". The home folder for "admin" is viewable from the Shares tab of the Admin Page. ...
- Apr 17, 2016
I resolved the problem. I went to the "Access" tab of the "Home Folders" and turned the SMB protocol OFF, then turned it back ON---and ouila', the "admin" subfolder under the "Home Folders" folder appeared and is functional to upload to, and now seen in Windows File Manager as I expected it should.
I'm thinking I may have accidentaly deleted it some months back that I don't remember when I was learning my way around and setting up other share folders. I simply don't remember, but all is well now.
JennC
Apr 16, 2016NETGEAR Employee Retired
Hello Ray2,
Did you create admin account or just the default admin account? You shouldn't because it will conflict with the default one.
And there is no other users that can get in to the admin page but just the admin account even if you have created other user accounts. These other user account are for accessing shares only.
- Ray2Apr 16, 2016Luminary
No, I didn't create any admin account or any other user accounts..
I only have the default "admin" acocunt.
- mdgm-ntgrApr 16, 2016NETGEAR Employee Retired
Can you provide a screenshot?
- Ray2Apr 17, 2016Luminary
