thuglife
Apr 30, 2023Aspirant
HELP Install Milestone Arcus Surveillance
Hello, I am trying to install Milestone Arcus Surveillance on ReadyNas 314 6.10.8, but when i click on install button i have this message : Are you able to help me ?
Apr 30, 2023Guru - Experienced User
Licenses for Arcus aren't available anymore - that ended in 12/31/2018. At that time, Netgear removed it from the app store.
See
Were you reinstalling for some reason?
- thuglifeApr 30, 2023Aspirant
I want to record on the NAS Camera with onvif protocol.
Do you have a solution ?
- StephenBApr 30, 2023Guru - Experienced User
Not something I do, but I suggest something like Blue Iris on a PC (using a NAS share for storage).
I don't know of any apps that can be installed on the NAS.
- SandsharkApr 30, 2023Sensei
Given the age of the Linux distro ReadyNAS OS is based on, installing anything is a chore, and likely will be a very old version if you do succeed. If it's not a ReadyNAS-specific build (that should already take care of it), you also need to insure it doesn't fill the very small OS partition with logs or other files (camera videos in this case).
I also personally believe than running a surveillance system on a headless NAS is not a good plan -- you need a video system.
I run Blue Iris on a PC and have my NAS set up as the archival data location, so not much stays on the PC running it for long..
