alokeprasad
Mar 17, 2012Mentor
Help me select between Netgear routers N600 and N900
I am looking to upgrade my cable router to support gigabit and 802.11 N wifi. I have a Sparc Duo and other Netgear switches like GS108. Anyone here have experience with N600 (WNDR3800) and/or N900...
ahpsi1
Mar 17, 2012Tutor
I've used both (currently use the N900) and can say I've had less problems with the N900. As far as speed goes it's tough to say - because of the mix of devices I have the G dialed down. The write-up and comparison table on Small Net Builders -> http://www.smallnetbuilder.com/wireless/wireless-reviews/31603-netgear-wndr4500-n900-wireless-dual-band-gigabit-router-reviewed might be helpful. The biggest gripe I had with the N600 was IPV6 seemed dodgy - but that was on an early firmware rev.
