Jojo90
Sep 26, 2015Tutor
Help needed : Is it possible to do an incremental backup on my RN104 ?
Hello all ! I own a ReadyNas DUO since many years, and never had any problem using it. But since I bought my new RN104 (firmware #6.2.5), I am totaly unable to do an incremental backup : it does fu...
EskenderNG
Sep 27, 2015NETGEAR Employee Retired
Hello,
What is your backup source/destination?
In case you are backing up from a Client PC to the ReadyNAS maybe the solution can be found here:
https://community.netgear.com/t5/New-to-ReadyNAS/Incremental-backup/m-p/974262
Bye,
Eskender
- Jojo90Sep 27, 2015Tutor
Hello Eskender,
I backup a FTP-source to a NAS-share.
I think that I use the timestamps option, so I will try to change (is it possible on FTP transfer ?) to the Archive Bit option...
I'll keep you updated ! ;)
