Jojo90
Sep 26, 2015Tutor
Help needed : Is it possible to do an incremental backup on my RN104 ?
Hello all ! I own a ReadyNas DUO since many years, and never had any problem using it. But since I bought my new RN104 (firmware #6.2.5), I am totaly unable to do an incremental backup : it does fu...
Jojo90
Sep 27, 2015Tutor
Hello Eskender,
I backup a FTP-source to a NAS-share.
I think that I use the timestamps option, so I will try to change (is it possible on FTP transfer ?) to the Archive Bit option...
I'll keep you updated ! ;)
mdgm-ntgr
Sep 27, 2015NETGEAR Employee Retired
Why not use Rsync rather than FTP?
- Jojo90Sep 28, 2015Tutor
Hello mdgm !
Just because I cannot activate Rsync protocol on the server on wich my files are located...
I only have FTP access.
Hello again !
I've justed checked : FTP backup is not compatible with archive bit, which only works with Windows Backup...
So, unfortunately, my problem is always relevant... :'(
If someone can help, has an idea, or better : has a solution, please, don't hesitate ! ;)
- Jojo90Dec 24, 2015Tutor
Always without solution... :'(
Don't hesitate, if you have an idea to solve my problem !
And merry christmas to all of you ! ;)
Jojo
