wannathermal
Feb 24, 2013Aspirant
HELP! No boot
Help me please. Yesterday my new NAS failed (I won`t mention make) so I went back to my NV+ that has been powered down for 2 weeks and when I push the power button nothing happens. I removed all the d...
Feb 26, 2013Guru - Experienced User
wannathermal wrote: So when my RM`'d unit gets here what is the process for repopulating the Server? Will just be able to Pop the drives and boot? Somehow I don't think so.
It is almost that easy (since the RMA replacement will also be a sparc-based system).
First put in a scratch disk (by itself), and go through a factory install. If the NAS is running a different firmware version then your old one, then install your firmware on it manually. (you can google site:readynas.com for the firmware download if you need it).
Then power down the NAS, remove the scratch disk, and insert your current drives into the same slots they were in before. Turn it on, and you should be good to go.
