hexo1
Jul 08, 2011Aspirant
Help on rsync between 2 Readynas Duo
Hi, I have a problem to backup one ReadyNas Duo to another one using Rsync. When I launch the backup, I got the task running without ending but no file is copied. The rsync works in on way but not ...
mdgm-ntgr
Jul 08, 2011NETGEAR Employee Retired
Have you ensured that you've set appropriate permissions for Rsync on the remote NAS to allow writing to the shares on the remote NAS you wish to write to? I assume you're running the backup job always on the local NAS?
