hexo1
Jul 08, 2011Aspirant
Help on rsync between 2 Readynas Duo
Hi, I have a problem to backup one ReadyNas Duo to another one using Rsync. When I launch the backup, I got the task running without ending but no file is copied. The rsync works in on way but not ...
hexo1
Jul 10, 2011Aspirant
mdgm wrote: Have you ensured that you've set appropriate permissions for Rsync on the remote NAS to allow writing to the shares on the remote NAS you wish to write to? I assume you're running the backup job always on the local NAS?
thanks for your answer.
I set the the permissions read/write for all users and groups. I have not defined any login/password for the rsync share. When defining the backup, the connexion test works fine.
I am using in the rsync parameters of the backuo tasks, the same user/password combination in the 2 setup. I have read in the user guide that anyway the user/password are useless if there is no rsync user/password setup.
I run the backups on the local NAS since I want to keep control and logs on the local device
Cheers
Nicolas
