DPH1968
Dec 30, 2020Aspirant
help R102
been using the NAS for monhs no problem, then had a power cut and it went to s##t....can do anything with it.....tried resetting the OS boot but nothing, tried accessing the drive via the admin page, nothing, enter the default user name as admin and password as password....nothing....also tried 1netgear as the password, again nothing.....power button is blinking, my IT knowledge is very poor but i need to get access to my photos and docs on the drive so cant afford to do a factory reset....i dont know what to so
- rn_enthusiastVirtuoso
Hi DPH1968
Have you tried to install RAIDar, to see what it reports of status?
Link here: https://kb.netgear.com/20684/ReadyNAS-Downloads
Scroll down to the RAIDar section and install "RAIDar 6.5 for Windows". Afterwards, open RAIDar and check what it say about the NAS.
That is a good place to start.
Cheers
- DPH1968Aspirant
ive installed the software and the status is showing as TFTP_REQ
Yes, this can happen sometimes. Usually a problem with the filesystem on the internal flash (the OS), a failing internal flash (which would mean bad chassis) or corrupt files on the internal flash. You can do a USB recovery to re-install the content of the Flash.
https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-systemWorth a go
- Jul 02, 2017Retired_Member
