mpj881
Nov 20, 2011Aspirant
Help setting up internet access
Hi, can someone please help me set up my routers so that i can access my nas setup and transmission over the internet. I have two routers in my house. First is the BT homehub this is on the networ...
WhoCares_
Nov 21, 2011Mentor
Since there are no security implications, you could also try to plug a LAN port of the Netgear router into the BT homehub. The Netgear device should then pick up an address from the BT's local network automatically which would then put all your devices in one local network. Would probably require a reboot of the ReadyNAS And other devices attached to the Netgear router so they'd pick up their new IP Addresses as well.
-Stefan
-Stefan
