mjw3786
May 25, 2011Aspirant
Help swapping "dead" drive? [Case #15693780]
Hey all, I have an NV+ that is about 2 months old. I fired it up and loaded it with all of our data, backed up all files from PC's etc...it has 4 x 2TB WD Green Caviar drives at this point. All is wel...
mjw3786
May 31, 2011Aspirant
Some more ideas:
Was looking through the log from startup a few minutes ago to look for possible issues unrelated to the drive and found this:
Is that referring to the system RAM? I did upgrade the RAM to a 1GB chip, but wouldn't I have other issues if that was bad? Hmm that's the first thing I saw. Then this:
Not sure what the "RAID superblock" is, but that probably shouldn't be invalid. That sounds important. And lastly:
Someone must have an idea what this indicates, right? How can the drive be "Dead" or "Not present" if it tests fine in the vendor tool. Windows was excited for me to format it when I popped it in to run the tool. :)
May 30 21:45:24 MULTIBEAST_8TB kernel: NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
May 30 21:45:24 MULTIBEAST_8TB kernel: Samsung NAND flash rev C
May 30 21:45:24 MULTIBEAST_8TB kernel: size of table 4096
May 30 21:45:24 MULTIBEAST_8TB kernel: table is there 0x8
May 30 21:45:24 MULTIBEAST_8TB kernel: bad block 2592 replacing by 4095
May 30 21:45:24 MULTIBEAST_8TB kernel: total bad block 1
May 30 21:45:24 MULTIBEAST_8TB kernel: bad 2592 = 4095 bad 4095 = -1 Total bad block number 1
May 30 21:45:24 MULTIBEAST_8TB kernel: retlen = 0x0200
May 30 21:45:24 MULTIBEAST_8TB kernel: VPD checksum = 0x10f7
May 30 21:45:24 MULTIBEAST_8TB kernel: ECC is ON
May 30 21:45:24 MULTIBEAST_8TB kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
May 30 21:45:24 MULTIBEAST_8TB kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
May 30 21:45:24 MULTIBEAST_8TB kernel: 0x00100000-0x03ffc000 : "P0 flash partition 2"
May 30 21:45:24 MULTIBEAST_8TB kernel: NEON flash: probing 8-bit flash bus
May 30 21:45:24 MULTIBEAST_8TB kernel: CFI: Found no NEON flash device at location zero
May 30 21:45:24 MULTIBEAST_8TB kernel: NEON flash: unknown flash device, mfr id 0x1, dev id 0x0
May 30 21:45:25 MULTIBEAST_8TB kernel: NEON flash: Found no Atmel device at location zero
May 30 21:45:25 MULTIBEAST_8TB kernel: This board is not supported.
May 30 21:45:25 MULTIBEAST_8TB kernel: X_RAID_START
May 30 21:45:25 MULTIBEAST_8TB kernel: startstop XRAID command = start, flash_cache=0
May 30 21:45:25 MULTIBEAST_8TB kernel: X_RAID clean shutdown indicator: 0x7.
May 30 21:45:25 MULTIBEAST_8TB kernel: dj_raid: invalid raid superblock magic on hdi
May 30 21:45:25 MULTIBEAST_8TB kernel: 0 2 2 1 0 0 0 0
May 30 21:45:25 MULTIBEAST_8TB kernel: 0 1 0 0
May 30 21:45:25 MULTIBEAST_8TB kernel: 1 0 0 0
May 30 21:45:25 MULTIBEAST_8TB kernel: 0 0 0 0
May 30 21:45:25 MULTIBEAST_8TB kernel: Update time for sb 1 = 4dd5b15f.
May 30 21:45:25 MULTIBEAST_8TB kernel: Update time for sb 2 = 4dd5b15f.
May 30 21:45:25 MULTIBEAST_8TB kernel: Update time for sb 3 = 4d85745d.
May 30 21:45:25 MULTIBEAST_8TB kernel: Update time for sb 4 = 0.
May 30 21:45:25 MULTIBEAST_8TB kernel: recent_ID = 1, select_ID=1, most_ID=2 right_mac=3
May 30 21:45:25 MULTIBEAST_8TB kernel: Selected sb 1, ctime=4dd5b15f, id=f5f2ab98.
May 30 21:45:25 MULTIBEAST_8TB kernel: Use this image: 1
May 30 21:45:54 MULTIBEAST_8TB kernel: sata_hotplug: /sbin/hotplug retry hdiUser mode helper start.
May 30 21:45:54 MULTIBEAST_8TB kernel: done do_sata_hotplug
May 30 21:45:57 MULTIBEAST_8TB kernel: IOERR: lp_stat=0x51, rq_sec=0x20, d_block=0x20, n_sect=0x20
May 30 21:45:57 MULTIBEAST_8TB kernel: IN MD: LP_ACTIVE=0, lp_error=64
May 30 21:45:57 MULTIBEAST_8TB kernel: ==== SATA init channel 3
May 30 21:45:57 MULTIBEAST_8TB kernel: After INIT SATA channel 3, retry=28, sata=113, status=50
May 30 21:45:57 MULTIBEAST_8TB kernel: Failing this request
May 30 21:45:57 MULTIBEAST_8TB kernel: Buffer I/O error on device hdi, logical block 2 (swapper)
May 30 21:45:57 MULTIBEAST_8TB kernel: Buffer I/O error on device hdi, logical block 3 (swapper)
May 30 21:45:57 MULTIBEAST_8TB kernel: Drive failed on channel 3, remove this drive.
May 30 21:45:57 MULTIBEAST_8TB kernel: Dump hwif 8041efb8 structure, 0-8041d398
May 30 21:45:57 MULTIBEAST_8TB kernel: 1-8041daa0|1-8041e1a8|1-8041e8b0|1-8041efb8
May 30 21:45:57 MULTIBEAST_8TB kernel: 0-8041f6c0|0-8041fdc8|0-804204d0|1-80420bd8
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->name---------------------ide4
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->hwgroup------------------81e95b40
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->irq----------------------35
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->present------------------1
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->hold---------------------1
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->noprobe^I^I^I0
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->true_device^I^I1
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->state0^I^I^I0
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].name----------hdi
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].present-------1
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].id_read-------1
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].noprobe^I0
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].dead^I^I0
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[0].id^I^I81e96940
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[1].present-------0
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->drives[1].id_read-------0
May 30 21:45:57 MULTIBEAST_8TB kernel: Warning:chn 3, there is a pending retry on req 80ff69b8, current req 80ff6568
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->irq = 35, retry 1
May 30 21:45:57 MULTIBEAST_8TB kernel: sata_hotplug: /sbin/hotplug retry hdiUser mode helper start.
May 30 21:45:57 MULTIBEAST_8TB kernel: hwif->irq = 35, fail 1
May 30 21:45:57 MULTIBEAST_8TB kernel: sata_hotplug: /sbin/hotplug fail hdiUser mode helper start.
May 30 21:45:57 MULTIBEAST_8TB kernel: done do_sata_hotplug
