mjw3786
May 25, 2011Aspirant
Help swapping "dead" drive? [Case #15693780]
Hey all, I have an NV+ that is about 2 months old. I fired it up and loaded it with all of our data, backed up all files from PC's etc...it has 4 x 2TB WD Green Caviar drives at this point. All is wel...
mdgm-ntgr
May 31, 2011NETGEAR Employee Retired
Did you run the memory test (http://www.readynas.com/forum/faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F) twice after upgrading the memory? Memory upgrades are not supported and incompatible memory can cause problems.
