mjw3786
May 25, 2011Aspirant
Help swapping "dead" drive? [Case #15693780]
Hey all, I have an NV+ that is about 2 months old. I fired it up and loaded it with all of our data, backed up all files from PC's etc...it has 4 x 2TB WD Green Caviar drives at this point. All is wel...
Bigbearf
Jun 01, 2011Aspirant
@mjw3786
LLCs are high. The highest on my 6 drives is 2467 and all of the others are under 1000. I would definitely see if you can use both WDIDLE and TLER on your drives. My last drive was the one that had a different firmware (see Sig) and it was not supposed to be able to be "TLERed" but it was. When I did it stopped the LLC escalation in its tracks. I would try both tools and also replace the original memory to eliminate any variables.
Hope this helps. Please post results.
bigbearf
bigbearf
