rsnellman
Feb 02, 2018Aspirant
HELP!!! Trying to establish a MGMT port on one of my 1 Gb NIC ports and establish iSCSI network on
Hi, I am trying to create / establish one of my four 1 Gb NIC ports as a MGMT port on my MGMT VLAN to access the ReadyNAS admin console for management purposes then utilize my two 10 Gb NIC ports on m...
- Feb 06, 2018
The ReadyNAS should be able to accommodate to your network configuration.
It sounds like the requirements are to seperate the MGTM and iSCSI traffic. There are two generial methods to do so as you mentioned, 1) VLAN configuration 2) Physical connections. In the two different methods to keep the connection/traffic seperated you would be looking at two different subnets.
Based on the performance issues that you have highlighted do not sound like it is specific to the size of the pipe. Adding an additional 1GE to make a 2xGE bond may not be the best approach if you are just needing MGMT. It will help with multiple connections in some performance cases, and improve reliablity.
We may need to have a better understanding on how you are attempting to connect to the unit (IP address, DNS, etc...)? Is the performance impact only the admin interface, or is the iSCSI performance imacted as well? Depending on these items, we may need to know the two different interfaces' subnets to make sure that the broadcast/chatter from the other network is not impacting performance.
rsnellman
Feb 05, 2018Aspirant
Hi Marc_V,
Actually, the reason I need to set it this way is because my iSCSI VLAN will be segemented and not talking across my network. So, I need to set the dual 10 Gbps NIC card on that VLAN, but then I wouldn't be able to access the MGMT side of the ReadyNAS without setting another NIC (one of the 1 Gbps ports) on my reachable MGMT VLAN.
So, it sounds like the ReadyNAS products are very limited in that aspect. I have tried it and it went hay wire, so it must not be possible. Thanks for confirming my findings/suspicions.
Have a great day.
rsnellman
Feb 06, 2018Aspirant
Hi Marc_V,
Can I at least bond multiple 1 Gb ports together to double my speed on this ReadyNAS running OS 6.6.0?
