iAmRockinRich
Dec 17, 2011Aspirant
help with backing up multiple PC's
I purchased shadow 5 to back up multiple computers. The problem I am having is how do I back up without one computer deleting files from another computer backup? I have four folders, DOCUMENTS MUSIC V...
iAmRockinRich
Oh Ok. I will look into syncback. seems pretty popular here. I use goodsync. I can do that but have to turn off deleting of files. You would think someone could make a software that could sync ONLY the files a PC put into a folder without touching other files from other PC's.
