dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
mdgm-ntgr
Oct 30, 2012NETGEAR Employee Retired
That is 4.1.10 (latest firmware). 4.01c1-p10 is using the old naming scheme. /var/log/raidiator_version would show the current naming scheme.
It was clear from the dmesg output that you had 4.1.9 or later due to the kernel version reported.
A
might indicate why Frontview isn't working.
You could try
and see if that brings Frontview online.
If you can get Frontview online then you could download the logs.
A
# tail /var/log/frontview/error.log
You could try
# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
