dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
dradams
I know that mdconfig says that it set something up, but it isn't a filesystem populated with my data. The 'c' directory is empty.
Library:/# uname -a
Linux Library 2.6.17.14ReadyNAS #1 Wed Jun 20 20:08:20 PDT 2012 padre unknown
Library:/# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
apache-ssl: Syntax error on line 1 of /etc/frontview/apache/httpd.conf: ServerRoot must be a valid directory
Library:/# ls /etc/frontview/apache/
27896a25.0 addons apache.pem c0a5503f.0 httpd.conf magic mime.types Ports.conf Shares.conf Shares.conf.1 ssl.crl ssl.crt ssl.csr ssleay.cnf ssl.key ssl.prm Virtual.conf
Library:/# ls /c
Library:/#
