dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
dradams
You are right, I was not using the correct nomenclature. Disks 0, 2 and 3 are fine. Disk 1 was the one that was having problems and is not excluded from the array. Yes, my USB disk was full, and I missed some backups prior to the power supply failure. At least I do have some data.
