dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
dradams
to clarify
Library:/sbin# mdconfig
Device : /dev/md0
Create Time : 1141072859
Update Time : 1351630768
RAID Level : 1
RAID Capacity : 2047936
Disk Size : 2047936
Chunk Size : 0
Disks : 3
RAID Disks : 4
Active Disks : 3
Working Disks : 3
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
Disk Device RAID Disk Maj/Min Sectors State
0 /dev/hdc1 0 22/ 1 4096000 6 [ Active Sync ]
1 /dev/hdg1 1 34/ 1 4096000 6 [ Active Sync ]
2 /dev/hdi1 2 56/ 1 4096000 6 [ Active Sync ]
Device : /dev/md1
Create Time : 1197898015
Update Time : 1335413102
RAID Level : 5
RAID Capacity : 1572672
Disk Size : 524224
Chunk Size : 16384
Disks : 3
RAID Disks : 4
Active Disks : 3
Working Disks : 3
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
0 /dev/hdc2 0 22/ 2 1048576 6 [ Active Sync ]
2 /dev/hdg2 2 34/ 2 1048576 6 [ Active Sync ]
3 /dev/hdi2 3 56/ 2 1048576 6 [ Active Sync ]
Device : /dev/md2
Create Time : 1141072860
Update Time : 1350873672
RAID Level : 5
RAID Capacity : 1164392448
Disk Size : 388130816
Chunk Size : 16384
Disks : 3
RAID Disks : 4
Active Disks : 3
Working Disks : 3
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
0 /dev/hdc3 0 22/ 3 776261806 6 [ Active Sync ]
2 /dev/hdg3 2 34/ 3 776261806 6 [ Active Sync ]
3 /dev/hdi3 3 56/ 3 776261806 6 [ Active Sync ]
Library:/sbin#
