dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
dradams
Library:/sbin# smartctl --all /dev/hdc
smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: SAMSUNG SpinPoint T166
Device Model: SAMSUNG HD501LJ
Serial Number: <REMOVED>
LU WWN Device Id: 5 0000f0 01bb00300
Firmware Version: CR100-12
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 3b
Local Time is: Tue Oct 30 18:00:33 2012 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 8998) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 153) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 253 100 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0007 100 100 015 Pre-fail Always - 7296
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 86
5 Reallocated_Sector_Ct 0x0033 253 253 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 253 253 051 Pre-fail Always - 0
8 Seek_Time_Performance 0x0025 253 253 015 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 36801
10 Spin_Retry_Count 0x0033 253 253 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0012 253 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 64
13 Read_Soft_Error_Rate 0x000e 100 100 000 Old_age Always - 195243
187 Reported_Uncorrect 0x0032 253 253 000 Old_age Always - 0
188 Command_Timeout 0x0032 253 253 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 071 057 000 Old_age Always - 29
194 Temperature_Celsius 0x0022 148 106 000 Old_age Always - 30
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 195243
196 Reallocated_Event_Count 0x0032 253 253 000 Old_age Always - 0
197 Total_Pending_Sectors 0x0012 253 253 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 253 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x000a 100 100 000 Old_age Always - 0
201 Soft_Read_Error_Rate 0x000a 253 100 000 Old_age Always - 0
202 Data_Address_Mark_Errs 0x0032 100 100 000 Old_age Always - 25
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Library:/sbin#
