dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
mdgm-ntgr
Oct 30, 2012NETGEAR Employee Retired
Looks like you're right then and the failed disk is the one that isn't showing up. I'd suggest making sure that the disk that is marked dead is removed then doing an OS Re-install.
