dradams
Oct 30, 2012Aspirant
Help with drive failure
Hi, I had a power supply failure on my ReadyNAS NV+ (I'm now on my third power supply). In the process, I apparently lost one of my disks. My raid array is not coming up. Would some kind soul be wi...
dradams
I'm not sure if I actually managed the OS reinstall because all my config is still there (I went through procedure with the recessed reset button, etc). Anyway, removing the bad drive may have been the fix in the end. Everything appears to be back up. MUCH thanks for the help!! (On to a fresh backup, a new drive and an a home-made power supply fan install.)
-David
-David
