jerryray
Oct 05, 2012Aspirant
Help with expansion
Over the last few days I replaced each of the four drives until complete. I went from 1 tb to 4tb drives. The unit is a NV+ latest firmware. I rebooted so the full size would be used. For the last ho...
PapaBear1
Oct 07, 2012Apprentice
You must have an older unit that originally shipped with RAIDiator 3.x which had 4K block size while 4.1.x uses a 16K block to be able to address a larger array with larger disks. The only thing you can do is a factory default which will wipe all the data which is why I asked about the status of your backup. Never, ever trust all your data to a single device, be it a single drive or a single box.
However, if you will open an online case with technical support they may be able to telenet in and get you access to the unit. At that point, you should definitely create and maintain a backup. When you open your case, please edit your first post and add the case number to the end of the subject line.
