Leothlon
Nov 08, 2015Aspirant
Help with file premissions
Hi.
I am looking for a way to set file permission so that any user can create files and folders but can only edit and delete their own files..
Example:
User A create file 1.
User A has full permissions on file 1.
user B can read file 1 but not delete or edit.
User B create folder 2
User A create file 3 inside folder 2.
User A can NOT delete folder 2.
So basicly read any file, edit and delete only on files you created yourself.
And admin has full permission on all files.
Example:
- LeothlonAspirantSo if i have write to a folder but only read on files inside that folder i can still delete the folder and thereby also deleting the files inside that i dont have permission on?
- BrianL2NETGEAR Employee Retired
Hi Leothlon,
Check these articles and let me know if this answers your question.
What access right options can I configure on my ReadyNAS OS 6 storage system?
How do I change default access rights to files and folders on my ReadyNAS OS 6 storage system?
How do I set network access rights to shared folders on my ReadyNAS OS 6 storage system?
ReadyNAS OS 6 - Setting sub-folder permissions in user security mode
Kind regards,
BrianL
NETGEAR Community Team
- LeothlonAspirantHi.
I have the readynas 104.
Ok is it then possible to delete folders but not files?
So user A create empty folder 1,
User B can delete the folder.
User A create file inside folder 1.
User B can no longer delete folder 1?
Or something along those lines...- BrianL2NETGEAR Employee Retired
Hi Leothlon,
I thought this was the scenario based on your first post.
Example:
user B can read file 1 but not delete or edit.If a user has read-write access to a folder or share, he/she will also have delete privileges. Just let me know if you have other questions.
Kind regards,
BrianL
Hi Leothlon,
With the given scenario that you posted, example #1 is more likely to happen but not example #2. Also, confirm the model of the ReadyNAS unit that are you using.
Kind regards,
BrianL
