jtedder's avatar
jtedder
help with netgear 104
i have installed about 9 tb of hard space on my new nas and it only shows i have 4.53 avaliable why
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Which brand and model disks and what capacity have you installed?
    X-RAID2 volumes have the capacity of all the disks - the largest for redundancy.
    • StephenB's avatar
      You do need to know the specific details of the disk sizes to compute capacity.  Your result is about right for 2x4TB+1TB, but is too low for 3x3TB.
      The rule for single redundancy is to sum the disks, and then subtract off the largest.  After that you need to convert TB to TiB (since the NAS reports TiB).  You do that by multiplying by .9 (value is approximate but close enough for most purposes).
      Let us know the sizes of your disks, and we can verify.  Model numbers might also be useful (since not all disks are compatible).
      • jtedder's avatar
        jtedder
        i have a4tb by wd a 3tb by wd and 2x 1 tb by wd
ProSupport for Business
