Dondi
Sep 12, 2016Follower
Help with Old ReadyNAS NV+
I am revisiting my ReadyNAS NV+ after a disk failure & replacement with the spare I had sitting next to the unit for such a scenario. I am looking at ordering a replacement spare drive and while sear...
bedlam1
Sep 12, 2016Prodigy
Raidiator 4.1.XX indicates you have a V1
The current latest version being 4.1.15
mdgm-ntgr
Sep 12, 2016NETGEAR Employee Retired
The V1 (which you have) is limited to 2TB disks.
The V2 always worked with disks > 2TB.
- StephenBSep 13, 2016Guru - Experienced User
When you do start running out of space, a good option is to get a new OS6 ReadyNAS with fresh disks. You can then repurpose your V1 NAS to back up critical data.
NAS-purposed disks (WD20EFRX, ST2000VN000) are good choices for your NV+. Warranty is three years, cost is similar to desktop drives, and both models are designed for NAS use (have TLER, etc). Or just get a new NAS when the next disk fails.
