johnb_pa
Jan 19, 2017Tutor
High smbd CPU usage
We've just gone live with a RN316 in a branch office, providing file storage for a small office. We're somewhat surprised to see the high CPU usage we're getting when only around 6 users may be s...
johnb_pa
Jan 19, 2017Tutor
A bit more information...
We're using ReadyNAS OS 6.6.1, and most of the clients are old Macs, running 10.4 upwards.
We've not enabled AFP because we're reluctant to use a protocol which should be going the way of the dodo...
It would be interesting to see if AFP (presumably Netatalk?) performs any better though.
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi johnb_pa,
Kindly try enabling AFP then observe. If it does the same thing, I suggest you call support. If its brand new, it should still be within the 90-day support.
- FramerVJan 27, 2017NETGEAR Employee Retired
Hi johnb_pa,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- johnb_paJan 27, 2017Tutor
We've not had a chance to test AFP access yet, but will do.
Sadly what we've had back from the users is that the ReadyNAS is performing much worse than the 10 year old Windows server which the NAS is replacing. :(
- FramerVFeb 03, 2017NETGEAR Employee Retired
Hi johnb_pa,
I see. Please let me know if the AFP made any difference.
