johnb_pa
Jan 19, 2017Tutor
High smbd CPU usage
We've just gone live with a RN316 in a branch office, providing file storage for a small office. We're somewhat surprised to see the high CPU usage we're getting when only around 6 users may be s...
johnb_pa
Jan 19, 2017Tutor
A bit more information...
We're using ReadyNAS OS 6.6.1, and most of the clients are old Macs, running 10.4 upwards.
We've not enabled AFP because we're reluctant to use a protocol which should be going the way of the dodo...
It would be interesting to see if AFP (presumably Netatalk?) performs any better though.
FramerV
Jan 21, 2017NETGEAR Employee Retired
Hi johnb_pa,
Kindly try enabling AFP then observe. If it does the same thing, I suggest you call support. If its brand new, it should still be within the 90-day support.
