macronencer
Aug 29, 2013Aspirant
Hit 8Tb limit - how to expand to 18T physical?
Hi all, hoping for suggestions here for an easy(ish) fix... first let me stress that I've had experience in UNIX and I'm not stupid, but my training is out of date and to be honest I find all the tech...
macronencer
Aug 30, 2013Aspirant
Thanks for the quick help StephenB, much obliged.
I've been busy since yesterday. I hot-swapped drive 3 from 2Tb to 3Tb, so now I have 3x3Tb in bays 1-3 and 3x2Tb in bays 4-6. Drive 3 took about 6 hours to do the RAID sync last night, and is actually now restriping (currently 74%) and has been for the last 9 hours, with a predicted 11 hours to completion. That seems very slow - is it normal?
Now when you say 15Tb, I assume you mean with 6x3Tb installed, is that right? If so, my sequence would be:
1 Upgrade drive 4 to 3Tb, making 4x3Tb + 2x2Tb (but still limited to 8Tb volume)
2 Back up the data (plus the OS and config) over the LAN
3 Factory reset and firmware update
4 Restore the OS and config
5 Restore the data
6 Upgrade the final two drives from 2Tb to 3Tb
Does that sound good?
I'm still trying to find a way to back up. I have installed rsync on my Mac Pro but until I can make the network authentication work, I'm a bit stuck, unless I want to go into the command shell and use tar myself (which I could do, but I'm nervous about screwing it up). A friend has suggested installing a VM on the Mac, and installing Linux on that so that NFS becomes easier (OS X makes it hard I think). I'm not sure I want to do that much stuff to my Mac Pro, as it's supposed to be a carefully-controlled workstation (I write music on it).
I'm the only user at the moment, but there are a couple of different file owners, because I am using the WD TV Live SMP and I found that it didn't work correctly unless I changed the media files to be owned by a special "nas" user. I can't remember exactly why now! But I'm not too worried about the permissions really, since I can always list them all before I start, and then change them back after the restore if I need to.
5 Restore the data
