macronencer
Aug 29, 2013Aspirant
Hit 8Tb limit - how to expand to 18T physical?
Hi all, hoping for suggestions here for an easy(ish) fix... first let me stress that I've had experience in UNIX and I'm not stupid, but my training is out of date and to be honest I find all the tech...
mdgm-ntgr
Sep 13, 2013NETGEAR Employee Retired
1. You would need to backup your data and do a factory default (wipes all data, settings, everything). There would be a 10 minute countdown in which you can open RAIDar and click setup and choose the RAID mode. After that if you haven't confirmed a RAID mode choice it will be chosen for you. When you click setup in RAIDar during the 10 minute countdown there is a checkbox under X-RAID2 which you can tick to choose to use dual-redundancy.
2. 13TB is the amount before overheads. Also 13TB is measuring where 1TB = 1000^4 Bytes (how disk manufacturers measure capacity) whereas the NAS like most PCs considers 1TB = 1024^4 Bytes. So 13/1024^4*1000^4=11.82. Allowing for overheads and rounding down it easy to get the 11TB figure.
