macronencer
Aug 29, 2013Aspirant
Hit 8Tb limit - how to expand to 18T physical?
Hi all, hoping for suggestions here for an easy(ish) fix... first let me stress that I've had experience in UNIX and I'm not stupid, but my training is out of date and to be honest I find all the tech...
macronencer
Sep 13, 2013Aspirant
StephenB wrote: Personally I think the power-of-10 units (TB) are more natural.
My recollection is that power-of-2 (TiB) was a Microsoft hack (back in the DOS days) because they wanted to avoid division, and use a right shift instead. The answer is close if you are looking at KB (back in the floppy disk days), but not so close by the time you reach TB/TiB.
Yes, I was aware of that.
I disagree that powers of 10 are 'natural'. Everyone is used to using powers of 2 when talking about memory, and it's a long-accepted standard, as natural to a geek like me as counting from 0, or writing dates as yyyy-mm-dd ;)
I believe some disk manufacturers even use a mixture (or used to), i.e. 1Mb was once used to signify 1024000 bytes... now, that's just as silly as it can get, I reckon!
