tgriffing
Mar 20, 2019Follower
Home Folder snapshots missing for some users
Using RN4312S with 6.9.5
In Home Folders, some users have snapshots, others do not. Is there a way to add snapshots to users without?
Missing snapshot folders are NOT visible from:
Co...
Hopchen
Mar 20, 2019Prodigy
Hi tgriffing
You can see if the users has snapshots enabled by going to (from the web GUI): Shares --> click the little cog wheel next to Home Folders --> select Settings --> to go the second tab: Snapshot Access. Does the user in question have "Protection" selected here? If not, then there is no snapshots being created for that user's home folder.
