Sairam
Feb 07, 2021Follower
Home Folder
Hi, I have ReadyNas 212 and been using it from last 3 yrs. I see suddently my folders disappered from the NAS admin page. However I can see all folder when I login from network and access them my c...
Sandshark
Feb 08, 2021Sensei
There is a script that can be run from SSH that can usually fix this issue. But you should first insure that the problem was not created by a too-full OS partition, or the script could fail and make things worse. An OS partition that's approaching full should be reported in the log (and via email alert if you have them set up), but rapid onset can cause the notifications to also fail. Using this requires that you are comfortable with SSH access to the Linux command line, especially if it's necessary for you to clean out the OS partition and make room. If you are not, then it is best to contact Netgear support. If you are, the we can guide you.
