BalROCK
Nov 05, 2016Aspirant
Host feature for SMB and FTP not working properly? OS 6.6.0
And yet another problem/question. On both of my NAS 204 the feature "Hosts" for shared folders appears to be not working at all (form SMB and FTP - did not check other protocols) FOR SMB - wh...
FramerV
Nov 07, 2016NETGEAR Employee Retired
Hi BalROCK,
I will check if I can replicate this. Do you have some screen shots that I can compare it to?
BalROCK
Nov 07, 2016Aspirant
I will be difficult to show entire problem on one screenshot. But I can try, just tell me which behavior you want to see on a screenshot :)
best regards,
- FramerVNov 08, 2016NETGEAR Employee Retired
Hi BalROCK,
You can provide multiple screen shots if needed.
- BalROCKNov 17, 2016Aspirant
sorry, for a delay :/
here you have some screenshots:
hosts looks normal just after enetring settings window
adding a host IP and ...
it jumps where it should be but ...
after clicking apply i am sent back to first pane and when I come back to hosts I see this ...
- FramerVNov 19, 2016NETGEAR Employee Retired
Hi BalROCK,
Thanks for the screen shot. By the way, have you tried clearing the cache?
I just came back to the office so I will try and check if I can simulate your issue.
Also, can you please try and send your logs to us.
How do I send all logs to ReadyNAS Community moderators?
- FramerVNov 10, 2016NETGEAR Employee Retired
Hi BalROCK,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
