wwalkersd
Oct 14, 2011Aspirant
How do I restore from external USB drive? [SOLVED]
I have regular Frontview backup jobs backing up all my user folders and shares to an external USB drive. Now I've had to factory default my NAS to get the upgrade to 4.1.8 to work, and I need to rest...
flaminio
Dec 06, 2011Aspirant
Trying to restore -- did a backup from Volume: c to USB device (completed successfully); now trying to do a restore, but "Volume: c" does not appear as an option for the "backup destination" (reversing the previous backup, as indicated in the above posts).
How do I restore the entire "c" volume?
Raaahbin
Sep 24, 2015Aspirant
I note this is marked as "solved", but I am running into this problem as well, and I don't see any solution in the thread. Was there a solution to all the things that are missing from the "destination" list?
I'm currently trying to restore two folders which are *not* shares (one is the timemachine folder, one is the transmission folder)... and as far as I can see, neither "timemachine" nor "volume: c" appear in the destination list... therefore one cannot restore directly to either of those things.
At this point, I'm planning to:
- create temporary shares (because you can restore to a share folder)
- restore to each of those shares
- SSH into the ReadyNAS and manually mv the share directories on top of the actual directories for each of those things
Is that really the best way to do this? It may seem rather "unix-y" to create backup jobs to restore, but making it asymmetrical is very un-unix-y. I can't help but think the folks at Netgear never actually needed to restore their ReadyNAS from a backup!
- StephenBSep 24, 2015Guru - Experienced User
I agree the backup job choices should be symmetrical.
If you are planning to use ssh anyway, you can of course simply copy the USB drive folder to the destination folder (even if it is not a share).
If you formatted the drive as NTFS, you can also connect it to a windows PC, access the data volume using admin credentials, and drag/drop the folders as you wish. Though in this scenario, owner/group will end up admin/admin.
- mdgm-ntgrSep 24, 2015NETGEAR Employee Retired
You would need to correct the ownership of the TM data back to what it should be.
If we allowed configuring a backup job to restore to the root of the data volume some users may mistakenly wipe all their data on the NAS. We don't want that to happen, so we don't allow that.- StephenBSep 25, 2015Guru - Experienced User
Then there should be a guide on how to fully restore the NAS from the backup.
