markauty
Sep 12, 2015Aspirant
How do i setup raid on my ready nas duo v2 after buying a new hard drive.
I have a Ready NA Duo v2 with 2 seagate 3TB disks in. RAIDar was showing that one of the disks was going to fail so I purchased a new identical drive and pu it in the drive. RAIDar sees the new ...
- Sep 14, 2015
Hi markauty,
You're welcome! Just let us know what happens.
Kind regards,
BrianL
NETGEAR Community
BrianL2
Sep 13, 2015NETGEAR Employee Retired
Hi markauty,
Reboot the ReadyNAS while the new drive is seated in one of the bays. Open the RAIDar utility and check if the drive has been detected and if the LED is blinking (if its blinking, it's probably doing a sync). If it still won't start the resync process on the said drive, turn the ReadyNAS off again then do the hot swap procedure.
Kind regards,
BrianL
NETGEAR Community
markauty
Sep 14, 2015Aspirant
Thanks!
Mark
- BrianL2Sep 14, 2015NETGEAR Employee Retired
Hi markauty,
Kind regards,
BrianL
NETGEAR Community - BrianL2Sep 29, 2015NETGEAR Employee Retired
Hi markauty,
Thank you for confirming that the issue that you reported has been resolved. Please continue to share your ideas, questions and suggestions in the community.
Kind regards,
BrianL
NETGEAR Community Team
