infowire
Oct 03, 2013Aspirant
How do i share folders over WAN (NAS RN104)
I set the local ip of the NAS as a DMZ, so the ports should be open. I have created users and folder and set permissions. (I am able map the folder for each user as a network drive in windows usi...
Oct 03, 2013Guru - Experienced User
Many ISP block the ports used by Windows file sharing, including comcast. http://customer.comcast.com/help-and-su ... ked-ports/
I suggest using https and ftps - both of which are secure. Filezilla is a good client for ftps.
I also would not put the NAS in the DMZ. Instead of I only forward the ports that are needed.
