ScottChapman
Dec 10, 2014Apprentice
How does bitrot protection actually work?
I understand the concept, but am curious how it is actually implemented on 6.2.0
- sgogoAspirantThanks mdgm!
- mdgm-ntgrNETGEAR Employee RetiredActually I enquired with one of our product engineers and had a clarification:
If there is a filesystem checksum mismatch, we try to re-assemble that RAID stripe in different ways until we get a checksum match. If we never get a checksum match, we give up and inform the user that we detected an error but couldn't correct it, as you've seen reported elsewhere. We never generate data to make the data match the checksum. It's about as safe as it can get.- pec967Luminary
Can bit rot protection be enabled on Home folders in OS 6.4.x? Unlike shared folders, there is not a check box to enable bit rot protection on Home folders.
I replaced a ReadyNAS Duo v1 with a RN312 in a RAID 1 configuration last year for home use. I only use the RN312 for user backups, and these backup files are written to folders in the users' Home directories. I then use ReadyNAS Vault to provide an off-site backup. I would certainly like to enable bit rot protection since many of the photos and music files in these incremental backups are static. Perhaps I need to create shared folders and then adjust the permissions to only allow access by the individual users?
I don't understand why ReadyNAS does not share more information on exactly how checksums, bit rot, and RAID reconstruction with checksums works in OS 6 for RAID 1, 5, and 6. While the information in this thread is helpful, I still have a number of questions. In the Enterprise storage array space, vendors like NetApp have always published in the open literature the specifics of how their checksums (data and metadata), file identity blocks, raid scrubbing, and bit rot work. For example, a Usenix paper in 2008 reported data for three years on 1.5 million disk drives in NetApp storage arrays at customer sites. Over this time, they found 400,000 checksum errors, of which 8% were discovered during RAID reconstruction often leading to data loss, The file identiy blocks identified an order of magnitude smaller number of errors due to things like lost or misdirected writes. The superior error handling performance of OS 6 is a selling point for ReadyNAS, particularly given the slower performance for the price compared to the competition, and you should step up and let your customers understand exactly how it works.
- sgogoAspirantMdgm-
That is great news! Thanks for following up!
SteveG Just got a RN316 and found this great thread. Thanks everyone for your helpful discussion of technical details. I plan on running a memtest any time before scrubbing.
Was also wondering about what scenarios bit rot protection would work, especially the scenarios snakyjake propsed in message 6.
Has anyone managed to find out any info about this from Netgear? It would be nice to know specifically if it will ever verify against checksums of data in snapshots, and not just RAID parity.
Is there a notification any time there's a checksum mismatch and not just when an error couldn't be corrected, or just a log entry generated in that scenario?
I did find a document at an EU Netgear site where it explains that BTRFS corrupt checksum events are sent to the md layer to find the correct data as mdgm said (thanks also for that information about use cases): ReadyNAS_Bit_Rot_Protection_Overview.pdf
This sheds a little more light on the mechanism, but not necessarily the technicals. Hope it gives slightly more clarity to the OP's question.
