McRob1
Mar 29, 2016Luminary
How long should it take to backup 4.2 TB of data to a external USB attached Disk
I am running firmware 6.5.0-T338. I attached a Toshiba external 5TB hard drive to my NAS 516 rear USB 3.0 Port. The drive is formated using NTFS. Created a incremental backup job on the NAS. I st...
Mar 29, 2016Guru - Experienced User
I measured about 24 MB/s on an RN102 with T322 ( https://community.netgear.com/t5/ReadyNAS-Beta-Release/6-5-0-T322-RN100-series-front-port-USB-performance-is-sluggish/m-p/1061142#U1061142 )
Though that was with an SSD drive, and the file sizes definitely matter.
But at that speed, your backup would have taken about 55 hours. You seem to be getting something around 6 MB/s. Is the toshiba a USB 3 drive? Or USB 2?
McRob1
The external drive is a Toshiba 5TB Canvio Desktop External Hard Drive P/N hdwc250xk3j1.
According the the specs it is a USB 3.0 drive that is also USB 2.0 compable.
Here is a link to the Toshiba web site.
http://us.toshiba.com/computers/storage/desktop/canvio-desk/hdwc250xk3j1
- mdgm-ntgrMar 29, 2016NETGEAR Employee Retired
If you download the logs, what is the date in bios_ver.log ?
- McRob1Mar 30, 2016Luminary
/sys/class/dmi/id/bios_date
04/16/2013
/sys/class/dmi/id/bios_version
4.6.5- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Did you see similar performance back when you were running e.g. 6.2.4?
Are you able to try a different filesystem e.g. EXT4?
