McRob1
Mar 29, 2016Luminary
How long should it take to backup 4.2 TB of data to a external USB attached Disk
I am running firmware 6.5.0-T338. I attached a Toshiba external 5TB hard drive to my NAS 516 rear USB 3.0 Port. The drive is formated using NTFS. Created a incremental backup job on the NAS. I st...
McRob1
The external drive is a Toshiba 5TB Canvio Desktop External Hard Drive P/N hdwc250xk3j1.
According the the specs it is a USB 3.0 drive that is also USB 2.0 compable.
Here is a link to the Toshiba web site.
http://us.toshiba.com/computers/storage/desktop/canvio-desk/hdwc250xk3j1
mdgm-ntgr
Mar 29, 2016NETGEAR Employee Retired
If you download the logs, what is the date in bios_ver.log ?
- McRob1Mar 30, 2016Luminary
/sys/class/dmi/id/bios_date
04/16/2013
/sys/class/dmi/id/bios_version
4.6.5- mdgm-ntgrMar 30, 2016NETGEAR Employee Retired
Did you see similar performance back when you were running e.g. 6.2.4?
Are you able to try a different filesystem e.g. EXT4?- McRob1Mar 30, 2016Luminary
I don't remember the performance being this bad when using 6.2.4.
I just reformatted the drive using the NAS as NTFS.
Should I try formatting using the NAS with EXT4?
