venturadeb
Apr 21, 2012Aspirant
How Long should it take
I bought an NV+ v1 by mistake. had it up and running with 3 three terrabyte drives in a few hours. BUT it was 750gb partitions. went ahead and bought the NV+ V2 and moved the drives. This of cours...
Apr 21, 2012Guru - Experienced User
-The available capacity is 9 TB in the SI units used by the drive manufacturers, with is 8.185 TiB (the units reported by ReadyNAS V1 and x86, and I think the V2). http://en.wikipedia.org/wiki/Terabyte
-Expanding the raid array rewrites every sector on every drive, even if the drives are empty. (It happens at the physical layer, below the file system).
