NASklr
Sep 25, 2015Aspirant
How Much Time to Format?
I have an RN102 (6.2.3) that I have removed the old 1TB discs and replaced with two identical 3TB WD reds. The 3TB discs were tested on a PC, then volumes deleted prior to installing in the RN102. I ...
NASklr
Sep 26, 2015Aspirant
To answer my question, it took all day for the activity light to quit flashing. let's say 12-24 hours for new disks to get configured.
For some odd reason I can no longer access the web ui through Raidar, because it uses my default browser, Firefox. Before I installed the new discs Firefox could access the web ui. Now it times out. IE11 still works.
- StephenBSep 26, 2015Guru - Experienced User
Firefox works fine with 6.2.5. It seems odd that 6.2.3 would fail.
- mdgm-ntgrSep 26, 2015NETGEAR Employee Retired
There can be web browser compatibility issues introduced by a web browser update. A firmware update is needed in such cases to resolve it. Not sure if this is one of those.
- NASklrSep 26, 2015Aspirant
Something to do with certificates. I went into Firefox settings and deleted old certs for my ReadyNAS, then told Firefox to trust it when I attempted to connect to the UI. That fixed it. (Raidar was trying to connect by IP. If I substituted the host name it connected fine.)
Restoring to factory defaults when I changed drives confused Firefox somehow.
It also confused me. I thought I couldn't connect to the UI while the drives were syncing because the NAS was busy. Apparently it was a certificate issue.
