themoldy1
Sep 20, 2011Aspirant
How to access data via USB
I've posted a separate topic on probable failure of my ReadyNAS Duo's network card. In the meantime I've got important data I need to get off the NAS. I tried plugging my laptop directly into it via ...
bbaraniec
Sep 20, 2011Luminary
You can't access Duo via USB cable and also Duo is running Linux so it will be not recognized under Windows.
You still can access your data but it requires Linux know how. If you have Linux machine you can and you know what LVM is then you can access your data.
Otherwise I would strongly advise to contact support if you still haven't or get in touch with someone who knows what LVM is.
