themoldy1
Sep 20, 2011Aspirant
How to access data via USB
I've posted a separate topic on probable failure of my ReadyNAS Duo's network card. In the meantime I've got important data I need to get off the NAS. I tried plugging my laptop directly into it via ...
bbaraniec
Sep 20, 2011Luminary
You can program the Backup button on the front of this device to execute one or more backup jobs that you have defined above. The jobs will be executed in the order that you specify here when the Backup button is pressed. If no jobs are selected for the button, depressing the button will backup the content of the backup share to the storage device connected to the front USB port.
So this isn't solution.
