James_Hee
Oct 30, 2009Aspirant
How to access FrontView in WAN
Anybody know how to access Netgear ReadyNAS Duo Frontview via a browser in WAN? Tried setting the router TCP port to 443 but still no luck. Any suggestion?
dpointbront
Nov 02, 2009Aspirant
Well since I posted last, I have installed SSH access on my ReadyNAS. Easy enough.
Now, what is the best way to access FrontView via SSH?
fdullemond wrote: Its not the transfer which is the problem..... because, as you mention already, it is secured by httpS.
As the URL you use can also be used by others on the web, someone might just Brute-Force your admin password... and if they succeed, then have total control over frontview.
This is a big enough security risc for me. I would not like someone to delete one of my shares from frontview...
Fred
P.S. Brute forcing in a browser is bothersome and timeconsuming, and therefore very unlikely. A real brute force attack will utilize unattended automated tools and speed per password check can be much higher than expected.
P.P.S. Ultimately it comes down to your 'sensitivity' to security and your perception of the risk you are actually taking.
