dhl
Sep 29, 2017Luminary
How to back up home folders with rsync?
I need a way to incrementally back up user home folders from our ReadyNAS Pro 6 main server to our ReadyNAS 104 backup server. Both are firmware current at 6.8.1. I've tried setting up rsync back...
Sep 29, 2017Guru - Experienced User
Can you post the details (source/destination, etc) of the backup jobs?
dhl
Here's a screenshot of the backup job pulling from the 104:
and this is the error when testing the connection:
What's the correct way to specify the home share on the destination?
Thanks!
- StephenBSep 30, 2017Guru - Experienced User
This is a push backup (the source is local, the destination is remote). Of course you'd need to have rsync enabled for "home" in the RN104.
This could be tricky since the NAS itself creates the "private" shares in home when new users access the NAS. The simplest approach is to create a HomeBackup share on the RN104, and make that the destination of the push backup that runs on the Pro.
- dhlSep 30, 2017Luminary
The example above was a failed attempt at a pull backup from the 104.
I tried a push backup from the Pro 6 and get a different error. Here are screen shots:
This is the Pro 6 source entered using the browse button:
This is the 104 destination. Rsync is enable for the backup share and test connection is successful:
Here's the error log:
I'm stumped. Thanks for your help!
By definition, if the source is local and the destination is remote, it is a push backup. And your screen shot clearly has a local source and a remote destination. It looks like it was backing up /home on the RN104 to the pro. A pull backup has a remote source and a local destination.
On the larger question - can you try switching your backup protocol on the Pro-6 backup job to SMB, and re-run it? Just to see if that works.
- SandsharkSep 30, 2017Sensei
StephenB wrote:This is a push backup (the source is local, the destination is remote). Of course you'd need to have rsync enabled for "home" in the RN104.
Which is not possible in the UI, it's greyed out. It's probably possible via SSH, but Netgear has probably disallowed it for a good reason (somethng to do with permissions or other security, perhaps). And any changes made in SSH are subject to being overwritten by the NAS and/or mess up something you didn't intend.
Or use a protocol other than rsync. Is there a reason Windows Timestamp doesn't work for you? It's less efficient than rsync, but can get the job done.
A more complicated way that might work is to create symlinks to the home folders in a share to which only admin has access but rsync is allowed. Rrsync can access a local home folder, just not a remote one where the protocol is not enabled, so the links need to be on the remote system regardless of whether it's a push or pull. But I'm not sure what rsync does with symlinks on the ReadyNAS -- follow the link or copy the link. Rsync has options for both, and I don't know what options are default on the NAS.
The only advantage I can see to this over the separate folder on the 104 is if the users need access to their backup directories and you have way too many users or constant flux in users where creating separate shares outside of home (for permissions control by user) and separate backup jobs for each of them is not practical.
I believe there is a suggestion in the Idea Exchange to allow rsync in home folders. I'm pretty sure that OS 4.x had it.
