robclarke411
Apr 01, 2012Aspirant
How to backup 15TB's of movies?!
Hi All, I have finally finished backing up my Blu-ray collection which took some time by copying the discs to a large Netgear ReadyNAS device. I plan to use this instead of the disks so will be relyi...
0r0r0r
Oct 31, 2012Aspirant
1. I think the best approach would be to buy a used ReadyNas that will accommodate 3Gig hard drives and copy the movie files from your existing ReadyNas using rsync.
2. Just name the movie files consistently using standard movie file names and the new file will overwrite the old file. There are some programs that will do this for you.
