portalman
Nov 30, 2020Aspirant
How to backup 4200 firmware USB stick?
How does one go about backing up the internal USB flash memory stick on a 4200 v2? Does this method also work for other x86 OS6 devices? Thanks
mdgm
Nov 30, 2020Virtuoso
Debug mode doesn’t use FTP to connect. Local access is via telnet.
Cloning the internal flash is not recommended. You are relying on the filesystem etc. being in a good state on that, and with devices that shipped with 4.2.x the flash has EEPROM data specific to that unit on it.
With models that shipped with OS6, USB Boot Recovery should be sufficient to put good firmware on the internal flash and get devices working properly again.
With legacy x86 devices such as the 4200 v2 there is a side effect of USB Boot Recovery which often leads to EEPROM data becoming corrupt.
Sandshark
Dec 01, 2020Sensei
I don't know how susceptible to failure the internal USB flash is on those units, but I don't see having a backup as a bad idea. I have images of the flash for all mine. USB recovery won't fix a non-working device.
If one is planning to do the conversion to OS6, then making a backup of a fully functional 4.2.x flash is a reasonable plan before proceeding. One of the few things that can (rarely) go terribly bad in the process is flash corruption, and having a backup of it would allow you to restore and try again.
If you purchased a unit that didn't come with the USB (some who sell them remove it thinking it contains personal data) and want to clone one from another unit, that would at least tell you if that's all you need to fix. But the serial number of the two units will end up the same. I don't know how the mods would feel about fixing the serial number in that case.
The flash also contains encrypted information regarding the model type, so you can't clone the flash from a 3200/4200V1 to a 4200V2, for example, and have it function properly.
