heinakenka
May 02, 2010Aspirant
How to (completely) unistall Twonky 6?
Hi, How to completely remove Twonky 6? I tried and did not find enough reasons to pay for it so how do I remove it? Seems that it leaves behind some directories and entries in some databases so...
margava1
Sep 04, 2010Aspirant
I want to use Squeezebox Server and port used is 9000 and twonky is not allowing to use the SqueezeBox.
How could I uninstall Twonky and use again the port 9000 ?
Thank you for the help
