heinakenka
May 02, 2010Aspirant
How to (completely) unistall Twonky 6?
Hi, How to completely remove Twonky 6? I tried and did not find enough reasons to pay for it so how do I remove it? Seems that it leaves behind some directories and entries in some databases so...
super_poussin
Dec 29, 2010Virtuoso
Try 6.0.30 it should uninstall twonky correctly
I'm trying to find a way to prevent system (not twonky) to create a media directory if not exist.
The 1st solution could be to set Twonky root to / instead of /media , but it means twonky will scan all the nas at 1st start
